What do I need to hook up amp with stock deck
Username: Cnc837
Norman, OK USA
I have 2 Kicker Comp Vr 10's and a 600 watt RMS Pioneer amp. What do I need to connect this to my stock deck. Its a 97 Chevrolet Silverado. Any comments would be greatly appreciated, Thanks
Username: Illuminator
Post Number: 1060
You'll need a line output converter. I don't recommend using it because it sounds terrible when compared to the output of a normal aftermarket headunit.
If you have an ebay account you can get a great deal on a used-but-in-new-condition aftermarket headunit which would be the best idea because most now offer some type of sound control for external amplifiers.
Username: Cnc837
Norman, OK USA
Will an RCA converter not connect it?
Post Number: 1061
Yeah, that's what a line output converter is...
Username: Cnc837
Norman, OK USA
Thanks for the help Jexx. So if i just get a bottom of the line say pioneer deck, that will give it good sound quality?
Post Number: 1066
It will give it great sound quality.
Username: Supraspyder420
Sammamish, Wa U.S.
Post Number: 72
I have a hi-low converter in my durango (soon to be replaced with HU) and it sounds good. Not great, but not poor. And its a easy/cheap add on for subs. And you keep your stock look.
Post Number: 1151
That's basically what was being said.
