What the Heck?
JonK
My friend has a JVC Cd player in his car, and it hasn't worked right ever since he had it installed. When you put a cd in or go to a radio station it doesn't play through the speakers, but the time goes on the display like it is playing. The other day he figured out that the way to make it come through his speakers is to simply tap his brake pedal lightly. What's the deal with that??? Please help...
Username: Cowtipper
Post Number: 9
im having kinda the same problem, no sound though the speakers, dont know if tapping the break helps but it that works check your wiring, a short or messed up wiring is probably the cause of that.
