Remote start proble,
the remote start part of my impulse security system that i hooked up to my 01 grand prix is giving me probles. it will start when i push the start button, but most of the time it will shut off after being started. i believe it is my factory alarm messing it up, but i cant tell if the factory system is off. need help badly
Username: Ps1k0
sounds like it isin't getting a good tach reading.
Username: Zacdavis~
Post Number: 90
01 grand prix, = PASSLOCK ||, you did bypass it, right?, sometimes they mess up, try directed's 555u they learn the code routine in seconds
