Epi need to know THE BEST!!!!!
Username: Rcjr9186
Charleston, SC United States
I need some help people. I have been to 3 different audio expert stores around here and im being told 3 different things, Kicker, JL Audio, and Planet Audio. Now what im looking for is simple, im looking for the best! Throw price out the window, plain and simple im looking for the best speaker, component, coaxial, and subwoofer. So can you help me, i want something that you can hear a mile away but also with GREAT sound quality. My car will eventually be a sound competition car so i have to have the best. So please, help me lol. thanks.
Username: Araknid
BOCA , FL U.S.
Post Number: 865
Out of those 3 i would say JL but are you willing to go with possibly other brands then that?
Username: Taylor17
Kopperl, Texas
Post Number: 2611
When you say "sound competition," do you mean spl?
Jl 12W7/13.5W7's are basically the best sql subs. As far as main stream brands.
Username: Mikechec9
Chicago/atlanta
Post Number: 431
there is not going to be any one best sub or one best component. some components are going to be more lively than others and some will be more neutral. it depends on what sounds good to you.
similar with subs
imo reputable components:
DLS
Dynaudio
Rainbow
Focal
Morel
CDT
reputable Subs:
ID Max http://www.imagedynamicsusa.com/pro...=idmax&type=sub
Digital Designs
http://www.ddaudio.com/dd/default.asp
Sound Spinter
http://www.soundsplinter.com/
Incriminator Audio
http://www.incriminatoraudio.com/
RE XXX
http://www.reaudio.com/html/
Ascedant Audio
http://www.ascendantaudio.com/
Adire Brahmas
http://adireaudio.com/
Atomics
http://www.atomicspeakers.com/produ...alypse/ap15d2.h tml
Elemental Designs
http://www.edesignaudio.com/us.php
Treo
http://www.treoonline.com/index.html
Crystal Comps
http://www.lightav.com/car/crystal/crystal.html
Diamond Audio D9
http://www.diamondaudio.com/product...&type=28&line=1
JL Audio
http://www.jlaudio.com/
Eclipse Ti
http://www.eclipse-web.com/
Beyond Audio
Dayton Titanic MarkIV
http://www.acoustic-visions.com/~acoustic/products/subwoofer_drivers/parts_titan ic_12_mkiii/
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8267
best components, no price limit?
Rainbow Reference or Platinum series.
best amplifiers? several to choose from.
Tru Technologies
McIntosh
Zapco
US Amps
Brax
Harrison Labs
Sinfoni
best subs? depends on your ear and your goals. for SQ, I'd go ID IDmax in an aperiodic enclosure.
of the three companies you listed though, forget the planet audio crap, kicker is middle of the road. JL is very good.. although not of the caliber of product I listed above.
for a head unit and signal processing, go Alpine F#1status. period. use their digital signal processing with their head unit, and connect your amplifiers to that.
If you need EQing beyond that, which is unlikely, look at Audiocontrol
sound deaden the entire car from roof to floorboards, trunk and firewall, doors, trunk lid, etc.
upgrade the entire electrical system. alternator, deep cycle batteries, isolator, proper gauge power cable, and fused d-blocks and a thermal circuit breaker at the battery
Username: Hellbender
Los Angeles, California USA
Post Number: 127
Hey Mike,, dont forget A/D/S in your speaker lineup! :P
Username: Mikechec9
Chicago/atlanta
Post Number: 451
yeah, i remember a/d/s from way back. they were really good back when soundstream was high end. i havn't heard much of anything from them lately. nothing at all really. saw an ad in a mag though (they still look good).
do you know if they are still quality or not?
Username: Mikechec9
Chicago/atlanta
Post Number: 452
i did forget to mention SEAS though. i havn't heard them , but i trust jonathan's recomendation.
