Best amp for JL Audio 10W7
Username: Shonzi
I've been seriously wanting to get a JL Audio 10W7 for quite a while and I was just wondering what would be the best amp for this type of W7, preferably nothing riduculously expensive. The cheaper the better. Great SQ is a must for me. Thanks.
Username: James1115
Wilton, Ct
Post Number: 3668
yeah I was thinking about buying a porsche with a 1.0 yugo engine in it also boy that would be cool.
Username: Subfanatic
Ky
Post Number: 4520
shawn, what he means is, if yo spend the moeny on the sub, spend even more on the amp
Username: Suleman36
Maryland U.S.A.
Post Number: 1665
Get the JL 500/1 if you want the best sq for it plus it matches your sub. YOu can find them cheap on ebay.
Ky
Post Number: 4524
go with a 1000/1
Username: Suleman36
Maryland U.S.A.
Post Number: 1666
subfanatic, this is only for a 10w7. The rms on this sub is 500 watts rms and we both know the JL 500/1 puts out more then 500 watts rms and close to 600 easy. You wont need more then the JL 500/1.
Ky
Post Number: 4525
nah, 1000/1 is way more neccesary haha
Username: Suleman36
Maryland U.S.A.
Post Number: 1667
You just wanna sell your 1000/1 amp...lol
again all you need is a 500/1 and your done.
