Audiobahn or Sony
DUB
I was wondering, which is better, the Audiobahn A8000T, or the Sony XM-DS1600P5.
The Audiobahn is 800 RMS @ 2ohms and the Sony is 900RMS @ 2ohms.
Yes I know, SONY (you can keep punding your keyboard if you want but this looks like a good amp.) Many people say that they lie about the watts they put out, but they cant lie all that much because the it would be false advertising, wouldent it.
Username: Jaackdeth
United States
Post Number: 218
Here is a site that has things in an order, and was made by someone who knows what they are doing. http://p079.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=48.topic
Username: Camaro823
British Colu... Canada
Post Number: 93
Sure they could lie, sony is a piece of sh!t company that makes inferior products. Sure it might be able to push out those numbers (not too sure) but the amp itself is horrible i talked to a&b Sound and they no longer carry sony amps due to all of them overheating and many customer complaints. So i would stay away as for audiobahn I can't really say since up here in BC its hard to find
DUB
Yea, I am pretty sure this guy has not had any kind of experience with no even half of those brands.
DUB
Alright then, here is something else, I am looking for a good mono amp, 800-1000 watts RMS @ 2 ohms, and try to keep it cheap if you can.
Username: Riebread77
Post Number: 301
The list is a little off, but it is expected because listening is subjective in many cases and depends on the application. For the most part though, its not that bad.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 640
MTX 801D They go for cheap on eBay, they are trustworthy, and they are just all around better than Sony and Audiobahn.
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 414
yea that mtx is good but if you absolutely have to go either sony or audiobahn that bahn will crush that sony amp
DUB
What about the Kenwood KAC-9152D?
Post Number: 423
kenwood amps arent very good neither
audiobahn >kenwood >sony
Username: Dtribe
Post Number: 62
The Xtant X 1001 is a good amp thaat puts out 1000@ 2 ohms
Jl 1000/1 will do it to but jl doesnt get it full potnetial unless it is on JL subs it is mainly for sq
Look around on ebay
Username: Dtribe
Post Number: 63
I got my Xant X for like 500 on ebay
DUB
Ok, lets just go with a 900 watt RMS amp, keep it cheap if you can, if there are any just over $200.
Post Number: 430
you could get an MTX thunder 942 for around that i own that amp its good...
DUB
Anything else?
