What amp will go with my JL W3's
Username: Ku692006
I have 2 10inch JL W3's (4ohm) the subs can handle 300 watts continuous. Can anyone recommend a couple of different amps that will power/match these subs. I'm on a budget (dam college) and I got these off a friend cheap. So if possible list some budget brands as well. Thanks
Username: Jaackdeth
United States
Post Number: 207
Check out this site, it gives some brands that are good and not so good, by a guy that knows his stuff.
http://p079.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=48.topic
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1408
If you have the "d4" w3's you need to be looking for a monoblock stable to 1 ohm or a typical 2 channel stable to 2 ohm stereo(4 ohm bridged).
A JBL bp600.1 would work:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5789167429&category=18796 %26
It delivers 600 watts into either a 1 or 2 ohm load.
-Fishy
Username: Ku692006
any other specific amps models I can look for?
