I was going to get two 12" audiobahn 400w RMS a sub... but now i am downgrading and getting two 10" 300wRMS a sub.. i am still going to use the audiobahn A8000T mono amp.. will my system still get the same low bass and bump with the tens?
The 10's will give you a tighter bass then the 12's, also most systems standard try and run 12's or a single 12 inch, because they are universal! The 12's would have MORE volume then the 10's
You couldn't compare because the 12"s would take more power. I had some Audiobahns a few years back, and they are crap, the subs anyways. How much do you have to spend?
o sh!t forget about that^ your gonna use that Bahn amp...you shouldnt be allowed to power an IDMAX with an audiobahn amp thats disrespectful lol,,,just get you some Type Rs and youll be fine
