Wiring in 2 head units
Username: Slimjim
Caro, MI US
Post Number: 14
Ok, I have a Pioneer system with a pioneer head unit. I am getting a DVD/AM/FM/CD/MP3 head unit and a 7 inch moniter. I would like to keep my pioneer head unit if possible. Is there any connectors out there that allow easy hook up of 2 head units?
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1437
If either of the h/u's have an aux-in just use that. However, unless the Pioneer is a much better unit with more features, etc. I don't see why you wouldn't just ditch it and use the DVD alone.
If you're really set on doing this and neither of the decks have an aux-in you could use an A/B switch like the $20 N-806 found here:
http://www.davidnavone.com/linedrivers.htm
-Fishy
