Good Match???
New Guy 12
I am going to get 1 alpine swr-1042d 10" sub and a JBL-BP600.1 as my amp. Will this work together??
Also do I have to hook up the voice coils seperatly?? How do I wire it to my sub????
Username: Thrushdtd
New York
Post Number: 216
if you baught the amp new it should come with wire peices to conect the voice coils in series. Positive to positive negative to negative. That will work amaizing i hooked my jbl 600.1 to one of my swr 1242 and it was just perfect for that sub so it will be the same for your 10". I have one for sale if you want it.
