CONFUSING DIMENSIONS
ok so im making a ported box for 2 15in cvr's and i have came to a road block
for a ported enclosure it says 3"x15.5" port, 22" long.... any clue what that means
i took it as the port will be a rectangle
3=width 15.5=height and 22=length/depth into box
is this right????
also if so it says that while making the box to only make it 17" deep???? if thats so then how to i put the port in it without it popping out the back-- or is supposed to be about 25in deep????
these are my current dimensions this is where im getting messed up
length=39in-- i figure 2 inches inbetween everything-side/port/sub/sub/port (from left to right)
depth=? how big are the subs and it says port should be 22in long??
height=16in im not sure though-1/2 in above each sub or should i go 17in to give a full inch above and below??
as you can tell i am completely hopeless as to what to do.. any help is appreciated
here is the manual for subshttp://www.kicker.com/05/tech-support/manuals/manuals/2005/2005%20CompVR%20Sub%2 0Manual.pdf
Username: Subfanatic
Ky
Post Number: 4360
your right on everyting, i checked it all, but see what it means is when you get to the end of the box, just turn the port, and keep it turning until you reach the desired 25 inches, lol, like it goes back then turns left until it gets there ya kow.
ok so this would be my dimensions
dimension #1
39L x 23w x 16h - with 1 in from back of port to back wall
dimension #2
39L x 17w x 17h
which is the preferred-
and.. with the #2 with the port would i use PVC piping or just add a wall wood and angle the cuts
or
should i stick with #1 so that the port goes straight back with no bending
port should be on right or left side if your looking head on at it
Ky
Post Number: 4362
if you want ill draw what you want to do up on paint and send it to you, do you have aim, if so im nushaganazad
im dbiock518 ill im u
would 5.21 cu ft be a good enough size for 2 15in kicker cvr in a ported box???
