Box Specs right???
Gutttt
I just got done building my box today...It is 25"wide x 17.25"high x 18" deep....i put a 3" circle port in and it is 11.25" long
I wont be able to test out the box till i get my amp. Did i build it right. And what is is tuned at and will it sound good. Its for a JL 15w3
Username: Kd7nfr
Montpelier, ID United States
Post Number: 355
Where did you get those measurments. (BEFORE I start to teach you how to figure it all out)
Gutttt
they are pretty close to the measurements on JL's website...just a little smaller because of my trunk space
Username: Kd7nfr
Post Number: 362
Should be fine then. As long as it's still tuned to the right frequency.
Gutttt
well whats the frequency??? Thats what i want to know
Username: Audioguy22
Post Number: 45
That looks right but you'll need two 11" long 3"dia ports.
Username: Subfanatic
Ky
Post Number: 4401
well i can help if i know if thats internally and what is the cubic feet after displacement? but this is what i got for those measurements and before displacement 4.42 cubic feet if trhose are internal and its tuned to like 18 for the frequency
Gutttt
they are external dimensions...i think that its around 3.3 cubic feet.........why would i need 2 ports?
Post Number: 46
Well, for starters thats what JL shows on there site.
http://www.jlaudio.com/subwoofers/pdfs/15W3v2_MAN.pdf
Post Number: 47
SORRY, I had the wrong pdf!
http://www.jlaudio.com/subwoofers/pdfs/15_18_W3_MAN.pdf
