Q. for amp space
Username: Kicker
Slave lake, Alberta Canada
Post Number: 92
i was just woundering about how much area does a amp need so it does not over heat? for instants under a seet is that o.k? can it be touching"
Username: Araknid
BOCA , FL U.S.
Post Number: 824
Ive seen and heard about poeple putting thier amp under there seat all the time but i would say if the amp has a cooling fan that it shouldn't be blocked with about an inch of clearance. It also depends on the heat sink the amp has, like if the amp uses the casing as the heat sink or internal or external.
Username: Kicker
Post Number: 93
how do you find this out
"the heat sink the amp has, like if the amp uses the casing as the heat sink or internal or external."
will it be in the instruction manual or on the amp it self
Username: Araknid
BOCA , FL U.S.
Post Number: 826
You could tell if the amp has external heat sink pretty easily just by seeing fins on the outside but if it was the casing or internal, if it was the casing the casing will be extremely hot to the touch after awhile of operating and if it was internal then you probably would have to take the casing off to see it. I'll see if i can find some pics for examples.
is there enough airflow in a trunk?
Username: Kicker
Post Number: 94
o.k well im pretty sure it is the casing one (thats the bottom right?) plus a fan, hell the best way to say it is that its a kicker 850.2 amp, so 1" is lots
Username: Supraspyder420
Sammamish, Wa U.S.
Post Number: 33
My amp (soundstream VGA600.2) get really hot when used for only 15-20 mins. I also have it in a tool box in the back of my durango. anyone have any ideas on how i can get it to stay cooler? or if any of you have/are knowledgeable of durango's then does anyone have a good idea on where to put the amp?
-sorry to change questions on this post. Its just the same topic.
Username: 54danny54
Post Number: 703
if it does overheat install 2 outboard fans lol
Username: Araknid
BOCA , FL U.S.
Post Number: 828
"is there enough airflow in a trunk?"
Well if there wasnt then nobody would put amps in there trunk.
