Like
Concept Amps
Username: Tbolt
Collipark, GA
Post Number: 227
Is the cd-2410 reliable.
Username: Tbolt
Collipark, GA
Post Number: 229
Also, is it really 90% efficient
Username: Invain
Michigan United States
Post Number: 3125
No way it's 90% efficient.
Username: Audiobass10
Cape Coral, FL United States
Post Number: 129
Class D amps are typically 60-70 percent efficient. Joe's right, that's BS about the concept amp.
Username: Invain
Post Number: 3126
Well, class D's can get up to 80% effecient. Class A/b's are usually in the 60% range.
But yeah, i've never seen an amp that's 90% effecient.
Post Number: 130
"Well, class D's can get up to 80% effecient. Class A/b's are usually in the 60% range.
But yeah, i've never seen an amp that's 90% effecient"
You're right, Class D is typically 70-80 percent efficient. I couldnt quite remember, but i figureed somebody would correct me if I was off. ::sticks foot in mouth:: High end companies like Mmats have make amps with rather high efficiency..still, I don't think they reach 90 percent.
Username: Tbolt
Collipark, GA
Post Number: 230
Here are the specs. http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1330815/vpcsid/0 /SFV/30046
Is it a good amp for the price anyway?
Andrew Quick
hey man I have the older series concept 2400w amp... the CC-D2400A, and it is extremely reliable and nice as long as you know what your doing ofcourse. Any perfect amp can be easily ruined if improperly used. Mine bench tested at 2045w at 1 ohm... very nice for my tastes, definetly pushes my 2 Avalanche 15s nicely... great prices as well... won't be disappointed...
Andrew
Username: Tbolt
Collipark, GA
Post Number: 250
Thanks bro. That's what I really needed to know.
Facebook
Shop Related Deals
Directory
