XXX or Digital Design
Username: Cstmsami
Crystal lake , Il United states
i was wondering which in ur opinion which makes a better 18'' sub?
Username: Eclipse2005
Vicenza, Vicenza Italy
Post Number: 156
I didnt know there was a 18" DD? What is it?
Username: Alpineuser
Winchester, TN
Post Number: 699
9917 they are both really well built subs. DD probably makes the "best" subs out of the 2 but the 9917 is 1400 i think and the XXX from re direct is like 459.
Username: Taylor17
Kopperl, Texas
Post Number: 2529
Yeah, but also... 2 totally different subs.
The x.x.x is an sq sub, and we all know what DD is.:-) lol
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8043
taylor's got this one right.
the DD is an SPL sub. the XXX is a long throw SQL sub.
if you want to compare, look at the DD and RE's MT, not the XXX.
then at least both are in the same genre
Username: Taylor17
Kopperl, Texas
Post Number: 2541
Lol, about time I get one right. hahah
Username: Supraspyder420
Sammamish, Wa U.S.
Post Number: 20
sorry to go off topic, but what has better SQ, the IDMAX 12" or XXX?
Username: Taylor17
Kopperl, Texas
Post Number: 2550
I'd go ID
Username: Cooldudejz
Post Number: 22
if you want an SQL sub why dont you go with the DD 9500 or 9100 series, i know they are still made for SPL but the SQ is good too, use should consider the 9512F or 15
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8049
the ID is probably better for SQ, although with less output than the XXX. Keep in mind though at that level you're going to depend a lot on install, power, and enclosure type, and not just the sub choice itself.
both are excellent subs
