2 15's and a 10
astrosafari
i got 2 300 watt 15's and one 10" jensen sub. should i go with a 350 watt amp for each 15 or 650 watt amp for both?? or should i go with like 1 1000-1200 watt amp for all 3? what should i do about the jensen sub? i have no idea how many watts it is. any body have an idea of what watts it could be?
Username: Perrydog
Flint, Michigan USA
Post Number: 113
are the 15's 300 max(probly not) or 300 rms?, what is the model # of the 10'?
Username: Perrydog
Flint, Michigan USA
Post Number: 114
to answer your ? i would personally go with an amp that has 650 rms NOT MAX and then i would find out what size the 10 is then get a sperate amp for that, this is if all your subs r SVC
