NEED HELP
Username: Jgut07
Post Number: 8
Im new at all this stuff. Im building a ported box for my JL 15w3. I want to be heard so im going ported. my JL is a D2. I know nothing about this stuff so dont laugh. But why is there 2 different places to hook wire to on the sub (a place on each side)....I am getting a 500 rms class D mono amp for this sub. Is all this right?.......my box is going to be 3.34 ft3
Username: Jgut07
Post Number: 9
the amp is 500 rms at 2 ohms...will that work with this sub...its only 250 rms at 4
Username: Kicker
Slave lake, Alberta Canada
Post Number: 76
your subs are what they call dual voice coils- (2dvc)you need to hook both them up or you will wreck your speakers.old subs were single voice coils- (1dvc)heres a site to show you what i mean
http://www.jlaudio.com/tutorials/wiring/index.html
Username: Jgut07
Post Number: 10
so if my sub is a d2 then i want to wire it in parallel at 1 ohm to get the max performance out of my sub???
Username: Jgut07
Post Number: 11
im going to be getting an amp like this
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=79830%26item%3D5785907812 %26
will this workout?
Username: Audiobass10
Cape Coral, FL United States
Post Number: 105
Terrible pick of amp to match with the JL sub. Don't expect the Sony to put out anywhere close to rated power or last very long.
Username: Jgut07
Post Number: 12
im heading into college and dont have 300 bucks to throw away on an amp....find a good amp for around 150 bucks on ebay then
Username: Jgut07
Post Number: 13
what sounds better...what is the difference between 2 and 4 ohms....and would getting a class d amp be worth it?
Username: Alpineuser
Winchester, TN
Post Number: 697
whats the rms on the sub and maybe i can help you out
Username: Jgut07
Post Number: 14
400 rms, thanks
Username: Araknid
BOCA , FL U.S.
Post Number: 778
Is it 4 ohm DVC or 2 ohm DVC?
Post Number: 108
There are no differences in a subs peformance whether it be dual 2ohm or 4ohm. The Dual 2 ohm sub can be wired parallel to yield a 1 ohm load, or wired in series to yield a 4 ohm load on teh amplifier. The dual 4 can be wired in parallel to yield 2ohms or series to yield 8 ohms.
Username: Araknid
BOCA , FL U.S.
Post Number: 779
I need to know the impendance so i can look for an amp and there are differences in parameters of subs of the same model line of different impendances, but i dont know if that would directly affect performance, It could but it depends on the situation.
Username: Jgut07
Post Number: 17
how can you tell what it is...the only thing it says on the back is ....JL 15w3 D2 dual voice coil subwoofer....
Username: Jgut07
Post Number: 18
http://www.jlaudio.com/subwoofers/pdfs/15_18_W3_MAN.pdf
This like is the owners manual to the sub
Username: Jgut07
Post Number: 22
also....will i need to put 2 speaker terminal plates on the back of my box so i can wire it?
