Port Size for box......HELP
Josh GUt
I just built a box today for my 15....i was wondering what size port to put in and how long.....the box is 3.3 cubic feet....i want loud bass....im only looking to put in a circular port ...just want to use pvc. JL's site says 3" round port w/ a lenght of 11.6" or something..does this sound right or not?
Thanks alot
Username: Invain
Michigan United States
Post Number: 3122
Well, seing as you didn't tell us what sub you have, then I have no idea. I'm sure whatever JL recommends will be fine.
Josh GUt
JL 15w3 d2
