WHAT THE HECK!!!! Kicker 12" CVR's Problems!
Username: Tylermoncrief
Post Number: 56
Yo...I got 2 Kicker CVRs 12" 2005 4 Ohm Model
Ok, I wired my speakers up to be 4 ohm
I got a Kenwood KAC-7252 amp
Its bridgeable
I bridged the speakers on the amp
2 on 1 positive
2 on 1 negative
For some reason it keeps blowing the fuses
Now on the kickers there're 2 dots on a negative
and positive. and the other 2 there isnt any dots
I wired the 2 dotless toghter
and wired the positive dot to the negative dot on the other speaker & Vice versa the negative on the other speaker.
Fuses keep blowing.
The Fuse that blows is a 40a fuse..not the fuse from amp kit to the battery
Know what the problem is?
Username: Audiobass10
Cape Coral, FL United States
Post Number: 84
hm. not really sure how you've got your wiring.
check it here: http://www.audiobahn.com/frame2004.html
Hate to use an audiobahn site, but their wiring calculator is helpful.
Username: Tbolt
Collipark, GA
Post Number: 175
The ones with the dots on them are the first vc. The dotless ones are the second vc. Thats all i can help you with.
Post Number: 57
Well...Ill tell you how I have them wired up
Left Sub - 1st Voice coil Poisitve is wired to the positive on the Right Sub Positive
2nd Voice Coil is wired to the Negative & Positive
(2nd Voice Coil)
Right Sub - 1st Voice coil Negative is wired to the Negative on the Left Sub Negative.
2nd Voice coil is wired to the Negative & Positive
(2nd Voice Coil)
Username: Tbolt
Collipark, GA
Post Number: 177
what did you mean by "I bridged the speakers on the amp
2 on 1 positive
2 on 1 negative" The speakers are hooked up correctly.
Post Number: 59
well...What I mean by that is
On the amp it has bridge on there
And since the wire comes in doubles
(negative and positive)
I got the positives hooked up to the amp on 1 terminal & the negatives hooked up to 1 terminal on the amp
Username: Tbolt
Collipark, GA
Post Number: 178
ok IC. the only problem i can think of is the amp being short circuited.
Post Number: 60
But how can it...And its 4 Ohm Bridgeable
and I got the speakers wired at 4 Ohms
It blows fuses like crazy.
Do you think the amp is getting to much power put to it
or does the speakers need to be re wired a different way
Username: Tbolt
Collipark, GA
Post Number: 179
No, the speakers are fine. What guage is the power wire.
Post Number: 62
Or should I wire 1 voice coil to the other voice coil?
Like (1 with a dot, to 1 without a dot)?
Post Number: 63
This I dont know...This is actually my friends car....It look thick..(------) Its about that wide
Username: Tbolt
Collipark, GA
Post Number: 180
It looks like about a 4 gauge. Thats good. I just read the kicker manual and it said that the first vc should be connected to the second vc like you said.
Post Number: 65
Yeah...That was my mistake! LOL...Thanks
I lost my manual
Username: Jonez788
Post Number: 128
There shouldn't be two positives and two negatives to hook up.
There should be on positive and one negative wire coming from the box.
Post Number: 66
How could I do that....Id cut the wire? where it has me hook up 1 speaker to another speaker?
Username: Tbolt
Collipark, GA
Post Number: 181
No don't cut the wire, just twist the two wires to make one wire.
Post Number: 67
Thanks that helped...Its working good now
It sounds good...But the sound doesnt travel far tho...Is there anyway to make the bass deaper so I could hear it from more further away
Is there anyway else, besides a different box?
Username: Tbolt
Collipark, GA
Post Number: 188
You don't want to be "heard." You want to keep the bass inside the car by using edead or something in the trunk. Then you could let your windows down if you want to be heard. Also make sure the speakers are wired in phase.
