Some good 8 inch woofers?
Username: Riebread77
Post Number: 265
What are some good 8 inch subwoofers that handle lots of power...anywhere up to 1000 watts.
Username: Audiobass10
Cape Coral, FL United States
Post Number: 101
Why do you want an 8" sub to handle all that power? The only sub I can think of that truley handles anywhere close to that much is the Kicker 8L7. If I were looking for an 8" driver I'd go with either an RE8 or Tang Band 8".
Username: Taylor17
Kopperl, Texas
Post Number: 2512
Lol yeah... does DD make an 8? Thats the only other brand that might make an 8 that would handle any where close to that.
Oh, maybe audiobahn? j/k
Post Number: 270
hmmm...not really sure...juss curious...b/c i see 10" subs 12" subs and 15" subs that handle the same amount of power throughout the model line (brahma's, xxx)...yet then the company's 8 inch models handle very little power...wonder why that is...if the 10" can have the same motor structure as a 15"...why can't the 8 inch have it too...
Username: Audioguy22
Post Number: 35
If someone needs to use an 8, its most likely a size issue.
If an 8 had the same motor of a 10~15 in would fall into a large
class of woofer than there be no point in useing an 8.
If you've good a very small old, you can still get an 8 in it if the
motor/magnet is small.
I'm a big Boston fan so I'd say go with the Boston 8.5 woofer.
somewhat small and can handle 700 watts.
Username: Alpineuser
Winchester, TN
Post Number: 698
http://forum.soundillusions.net/showthread.php?p=468313#post468313
here is an independent review of some 8s. Was done pretty well
