93 Altima Active Speaker sound package??? made by Clarion
Newbie with prob
I have a 93 Altima with the "premium" sound package...it has seprate amps in the trunk for front and rear speakers..... if i instal a new head unit and speakers am i going to have to re wire the whole system????
Username: Illuminator
Post Number: 1057
That isn't necessary, they should sell a wiring harness to bypass the amplifier.
Newbie with prob
hey where could i get a wiring harness like that????
i already got the one that connects the stock headunit hook up to a aftermarket head unit.... is there another adapter that i should be getting???
Post Number: 1062
http://www.crutchfield.com/cgi-bin/ProdView.asp?i=142C4NN02&search=142C4NN02
You might find it cheaper on ebay if they have it...
Username: Ehostler
VA
Post Number: 41
My truck has the infinity sound system. It has the amps at the speakers. I just used the amp trigger feed from the aftermarket head unit. All is good.
The only reason I would look into bypassing the factory amps is if you're going to be using new speakers and new amps.
