Rms and power
Username: Qup2cit
Australia
Post Number: 42
if a speakers rms is say 350watts and their rms is 100 watts, what would happen if say i put 160watts rms into them or would they work fine if not better than just giving them 100 watts rms
Username: Scubasteve
Annapolis, MD
Post Number: 145
"if a speakers rms is say 350watts and their rms is 100 watts..."
never heard of that before :-)
anyway, i've never seen a more confusing question asked on this forum. please clarify.
Username: Jonathan_f
GA USA
Post Number: 4256
He means a 350 watt peak rated speaker, with a true 100W RMS rating. The 100W RMS rating is thermal, meaning it can withstand the heat of 100 watts of power. Anything above that is risking it, but remember that a 100W RMS amplifiers is only going to produce it for a little while due to the dynamic nature of music. You'll rarely use all that power. That being said, if you're careful not to overdrive the speakers, a 160W RMS amplifier won't hurt a bit.
Username: Qup2cit
Australia
Post Number: 43
thanks jonathan, i did mean peak power instead of rms. thanks
Username: Glasswolf
Wisteria, Lane USA
Post Number: 7937
RMS is continuous, or what your amplifier's RMS should not exceed with that speaker.
the peak rating isn't that useful but it's a momentary rating, or how much the speaker can handle for a brief exposure without pretty much cooking.
stick to continuous or RMS ratings for amps and speakers both
