Mixing subs
Username: Allsevenz
South jersey
y is using 2 different subs in one box(with seperate chambers)with 2 amps bad? or is it
Username: Tbolt
Collipark, GA
Post Number: 60
Every sub has its own sound, so if you use 2 different subs you may notice one sub is louder or sounds better than the other one. The subs will sound off, I guarantee you that. Using 2 amps wit 2 different subs makes it even worse
Username: Taylor17
Kopperl, Texas
Post Number: 2404
It isn't bad on anything, but yeah, it will sound/feel different, and prob won't sound that good.
Username: Jmloughrey
Farmington, CT
Post Number: 1305
yea dude, at that rate, burn your system.
Username: Tbolt
Collipark, GA
Post Number: 61
you never know you might, and I say MIGHT find two good subs that work well together, but you'll probaly have a better chance of winning a million dollars. lol
Username: Allsevenz
South jersey
thx i got a sub backorder a diamond audio and audiobahn now i just get another audiobahn
Username: Thx_3417
Bournemouth, Dorset United Kingdom
Post Number: 653
Use all the same sub bass units = power
