Hifonics amps and jl amps
hipopopanonymous
on there 1000/1 amp and the bx1500d amp there are 4 speaker ports but its a mono amp, how does this work???
Username: Jaackdeth
Burnett, WI United States
Post Number: 129
bump
Username: Audiobass10
Cape Coral, FL United States
Post Number: 83
Makes it easier to wire multiple subs.
Username: Jaackdeth
Post Number: 130
Ok, so if you have 2 subs wired to 1 ohm, and have just a + and a - wire, which of the 4 posts do they go to?
Post Number: 90
"Ok, so if you have 2 subs wired to 1 ohm, and have just a + and a - wire, which of the 4 posts do they go to?"
Doesn't matter.
