CAPACITOr
Username: Mustang_guy
Post Number: 27
any comments on capacitors????????
Username: Taylor17
Kopperl, Texas
Post Number: 2338
I don't really like them that much. Some of them look cool, but other than that, I don't see much use in one.
Post Number: 30
Username: Loc_out
Post Number: 253
they suck
Post Number: 34
why doesnt it help u to not drain all ur battery out???
Username: Geekbike
Post Number: 305
A capacitor put more of a load on your alternator. as any addition in the electrical system, but saves a small amount of energy (fractions of a second worth) for use during deep bass hits. Also, they help stiffen your voltage rails to provide a more even flow of energy. If you need a capacitor to fix your dimming or what not, you might as just spend the money on an alternator. The one you are using will eventually burn out if it's being overrun continuously.
Username: Livinloud7
Post Number: 23
There used as a quick soruce of power when a note or notes is needed for an extra "kick" so to say. A capacitor charges and discharges very rapidly, however your Battery must recharge it quite often. An HO Alternator may be better idea though, depending on your situation.
Post Number: 38
ok then what kind of altenator should i get??
Username: Big_oso
Post Number: 60
it all depends on what your running in your car equipment wise
Post Number: 41
well i got the car itself(duh), 1 Gothic series power acoustic 800 watt amp w/ 2 kicker comps, and my under carrage neon lights
