New member Username: SoberskullSan Lorenzo, California United States Post Number: 7 Registered: Jun-05 | I'm preparing a new install in my chevy suburban Now i have a box with 1 15" and 2 12"s. (picture attached). Now, I am thinking about getting 1 whole amp for all 3. But I was thinking, if I get 3 different amps, I was going to connect them like this. From the RCA cable coming from my head unit, use a 2 Y connecters and hook them up to the amp that way. Would that use/differ the volts that my head unit is putting out, or would it still be 3 volts for each amplifer. (My head unit puts out 3 volts). I was also seeing that on all 3 amps, there is RCA outs. What if I connected the RCA from the headunit to 1 amp, then connect that amps RCA outs to the next RCA amps in ect. Would each amp get 3 volts or what? Sorry if i'm a bit comfusing, and thanks all for your help.<br>![]() |
Silver Member Username: GeekbikePost Number: 244 Registered: Dec-04 | Voltage is constant along parallel circuits, there will be no change. |
Bronze Member Username: FandimReno, Nevada United State... Post Number: 23 Registered: Jun-05 | You would be MUCH, MUCH, better off using seperate RCA's. ![]() ![]() Seth |
Bronze Member Username: SoberskullSan Lorenzo, California United States Post Number: 12 Registered: Jun-05 | Alright. Thanks for your help. ![]() |
Silver Member Username: Jonez788Post Number: 116 Registered: Jun-04 | Whoa dude, I am looking into getting a box jsut like that. Could you by any chance send me the dimensions for that box you have? jonez788@gmail.com |
