High powered alternators
Username: Dougfisher_05
where can i find a high powered alternator for a honda civic (1989). also my old alternator (the one that came with the car) and im guessin it was my sound system that killed. put a brand new one in, would it be safe to run the sound system again or not. any help appreciated
energizer
the best site i've found was www.mralternator.com
Username: Tim_9872
Post Number: 33
How many amps are you using for your sound system and how many amps is your alternator able to put out. Given that it is a 1989 Civic I would have to guess at 60-75 amps.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1534
check eBay.
I see Accord and Civic alternators on there for dirt cheap all the time.
under $200.
usually in the 120-130A range. stock is usually around 60-70A
Username: Aron
i have a kx800.2 bridged to a 12" L7 in a 2001 dodge ram with an alternator rated at 136amps, but when i turn my system up loud the amp cuts out and the protection light turns on, when i turn in down it turns back on and keeps playing. shouldnt that alternator be enough to run that amp, is there a way i can get my amp to stop cutting out?
aaron....you need a bigger alt.
that amp is drawing alot of amps!!!Its a class AB amp...
its prolly drawing the most part of that 136A!!!get something like a 160A-180A
