Wire in parralel
Username: Daddy_phat_sack
Post Number: 283
how do u wire something in paralel or in a series? i want to do this to my subs so i can bridge them both.
Username: Thx_3417
Bournemouth, Dorset United Kingdom
Post Number: 596
How to wire the speaker as + positive and -- negative, so if you have to speakers and one amplifier take the + and connect it to the + on the sub then from the first sub bass unit take a cable from the - negative and connect it to the + on the other sub bass unit, then take the last cable from the second sub bass unit back to the amplifier and connect it to the -- negative output terminals it is now wired in series....
Username: Thx_3417
Post Number: 597
Also bear in mind the impedance as well of the sub bass and the amplifier, and the impedance load, be careful as not to damage the units, also the series mode the SPL will drop by around -3db, however if you do it in parallel that is + and -- connecting from sub bass unit 1 to sub bass unit 2 + into + and -- into - / this will double the SPL by +3db not at certain frequencies this may curse a popping sound so be extra careful please....
And good luck....
Username: Matt12490
Post Number: 66
http://www.jlaudio.com/tutorials/wiring/index.html
there is an example for you... hope it helps a little more than just words
