Wiring MTX4250 Amp to UL-D612 Sub (6ohm)
Trying to connect,
MTX 4250D Thunder Mono Amp.
Key Features
Amplifier Type Mono Channel
Bass Boost With Bass Boost
Bridgable Not Bridgable
Power Output
RMS Power at 2 Ohms 250 W x 1
RMS Power at 4 Ohms 125 W x 1
Performance
Frequency Response 20 Hz - 200 Hz
Low - Pass Frequency 40 Hz - 200 Hz
Signal to Noise Ratio 100 dB
Bass Boost Frequency 40 Hz
THD at Rated RMS Power 1 %
Other Features
Input Voltage 12.5 volt
MOSFET amp Yes
3 Way Ready No
And
ULTRA LINEAR ULD612 12" SUBWOOFER
* 450W RMS
* 900W Max
* Dual 6 Ohm Voice Coil
* Double Stacked Magnet
* Die Cast Basket
* Butyl Rubber Surround
* Sensitivity: 87 dB @ 1w/1m
* Frequency Response: 25Hz - 3kHz
Is this possible plain and simple...Readin Ohm law as u read.
Option 1 (parallel) = 3 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
Option 2 (series) = 12 ohm load
Voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
Which wiring option would u picked with my sub/amp.
