Ported or Sealed???
Username: Riebread77
Post Number: 35
I have an Eclipse SW9152 Pro Quad 1 ohm voice coil subwoofer (5000 watts max and 3000 watts RMS) and a MA Audio HK-802SX (4400 watts X 1 max and 2200 X 1 RMS)...
I'm looking for loud, accurate sound. I listen to rap and trance.
What are some opinions. Should I go with a ported box or a large sealed box and why?
Username: Aaronmiiller
Post Number: 36
Big ported man. The more air you move the harder hittin its gonna be bro. Make sure if your building or buying to put your sub in a ported box that has a slot port though.
Username: Alpineuser
Winchester, TN
Post Number: 603
loud and accurate are hard to achieve. Are you willing to spend some money to get a box made? If so look into getting a rear loaded horn made for it or a snail shell made for it.
Username: Taylor17
Kopperl, Texas
Post Number: 2265
With a sub like that, loud shouldn't be hard, as long as you power it with a good amp. I'd go ported for that sub.
BTW, what amp are you going to run it with?
Username: Cheapskate
Post Number: 167
ported = loud
sealed = accurate
Post Number: 41
The sub itself is pretty much top of the line...The amp is a hk-802sw (4400 x 1 max; 2200 x 1 rms) and packs lots of power...While reading a review on the sub, someone hit 155 db with a 1500 watt rms MA audio amp with a 3.41 cubic box and I will be running more power. 155 db is plenty for my taste...what do you guys think it would hit with a large sealed box?
Post Number: 42
hk-802sx...typo
Post Number: 47
any other opinions?
Username: Iufan4lifeul
Louisville, Kentucky
Post Number: 160
Can't go wrong with sealed. You already have a big a$$ subwoofer and amplifier that will be VERY VERY VERY loud so why not gain some accuracy and go sealed? Ported is only if your short on power and want a little boost, but you lose some SQ. Mainly what you will notice with sealed is that the bass will be "tighter". Go sealed in my opinion, good luck.
Post Number: 50
Thanks. I'm starting to think sealed considering it's for a daily driver haha...what do you think about how many cubic feet of air space?
Post Number: 175
read up on your woofer's specs and study thiele small parameters to find the "optimal" Q (volume) you should be aiming for.
a Q of 1.0 is generally considered "optimal" all around
while a Q of 0.8 is considered optimal for tight bass.
calculating with thiele small parameters... you can find the perfect volume for any woofer.
i'd vote for sealed enclosures too. when you have a fast bass sound like a bass drum... a sealed woofer will punch you harder while a ported one will shake you harder with *wooo wooo woo* "one note bass".
ported woofers blurr the crap out of bass detail. i despise ported... but other despise sealed. it depends on the sound you're after.
i think you'd impress a listener more with bass that sounds like they're getting hit with a giant rubber mallet than an even larger rubber balloon... but that's my priorities.
sealed = *thump thump thump*
ported = *booooooooom boooooooooooom booooooooom*
Post Number: 99
thanks budged minded...thats helps a lot in my decision.
