Help with my eclipse cd8454 head unit
Username: Al123
Ok i have been going over the manual but am I confused but it does not mention anything about a subwoofer control fuction? It has a function for bass and thats it but not for just the subwoofer. Do I have to adjust the gain on the amp every time I want the subs to pump louder. I would expect that with such a high quality head unit as this I would have this control. Also the headunit came with a microphone and I have no idea what its for. It doesnt say anything about it in the manual.
Username: Illuminator
Post Number: 711
All right, the gain isn't a volume control necessarily and should be set to the same voltage that the headunit puts out.
The subwoofer control should be in there, but since I have had no experience with that deck, I can't really help...
The microphone is probably supposed to be plugged into the unit at some point so it can measure the vehicle's acoustics and adjust for best sound.
