Which amp will put out 800w??
Username: Iowahawks19
Post Number: 86
kicker 600.1
mtx801d
audiobahn a800t
(i need 800wrms@2ohms) which will put out that??
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 99
the mtx
Post Number: 89
yea thats what i was thinking too but it says 500wrms at 12.2 v and 800w at 14.4... so would the kicker 600.1 be better
btw it'll be pushing 2 12" cvr, im makin a budget system so the amp has to be about 200$
Username: Big_ed
Post Number: 46
jl audio e1800
Post Number: 91
i doubt jl makes a 200$ amp.. but ill check on it ed thanks
Username: Darkseid
Post Number: 79
between those amps, go with the mtx. The kicker's 600 is also at 14.4
Username: Riebread77
Post Number: 51
I have a Rockford Fosgate Power 1501bd for sale. I used it to power two 12" Kicker L7's and it slammed. I used it for only 3 months, then I sold my car and has been sitting around for awhile. its rated at 1650+ watts @ 2 ohms. I bought the amp for $575. It can be yours for $325 shipped (US). Email me at riebread77@aol.com if your interested.
Username: Fandim
Post Number: 9
I'm very fond of the audiobahn A8000T, personally. (800RMS @ 2ohms) Have slammed it for hours without any overheating or loss in quality.
Post Number: 98
i'll pass on that rockford ryan simpaly because im making a budget system, thanks for the offer tho,
are you sure that mtx will do the job?? does it really matter THAT much which amp i choose out of these three(should i simpaly go for which is cheaper)out of these-
mtx801d
audiobahna800t
kicker kx600.1
Post Number: 107
all 3 amps are good so i dont think it matters although the mtx will probably sound a little better
Username: Darkseid
Post Number: 80
its not gonna make a huge difference esp. in subwoofers. Those small differences in wattages are barely audible. The mtx will not have a problem pushing your setup. Remember it doesn't necessarily take the full rms of your speakers to reach there full potential, depending on your enclosure of course.
Post Number: 105
ok thanks guys... i'll just go for the one i can get the best deal on, haha im going for a really good budget system, goal is under 350$, but i think it's too low
btw they'll most likely be in a sealed enclosure
