A budget system
Username: Daddy_phat_sack
Post Number: 269
i need to make a budget system for myself :D. it will be my fist system. i have around 200 for an amp, subs, and shipping costs. any recomendations will be awesome. i was thinking about getting some volfenhag zx4712 12"s off ebay. thier really cheap and from wat ive heard are pretty good. i was also thinking about getting a pyle 2 channel 1000 watt eternal moseft amp. is this a good starter? come on guys help me out and thanks in advance.
Username: Kaos15th
Phoenix, Arizona USA
Post Number: 57
get an audiobahn a 8002t 8000t those will push those subs nicely. i think TB has that same set up with the volfehangs and audiobahn amp and he was pleased with it it rattled every mirror in his car he said. That's the only amp i could think of right now. for under $200. and Brandon i think you've been here long enough to know that Pyle is crap.
Username: Kaos15th
Post Number: 58
oh i just reread your post and you want an amp and subs for 200 i dont thnk thats gonna happen. save up like 100 dollars more and you'll find sumthing.
Post Number: 271
ok thanks man
Username: Insearchofbass
Post Number: 3054
brandon i told you how to do it budget wise its up to you
Username: Iowahawks19
Post Number: 85
for 200$, only get 1 sub, it's your only hope
Post Number: 272
yea im goin to get one 15.... ne good subs around 100 dollars??? lol
Username: Invictuz
Seattle, Wa Usa
Post Number: 67
You can get an ok deal if your really do some research before you purchase, but at 100$ for a 15" you really limit your options.
Do you already have an enclosure?
try these new 15" subs: http://search.ebay.com/15-sub-new
Post Number: 93
kicker cvr i would think is your best bet... it's 500wrms so find a 500w amp too
Post Number: 274
i can get a memphis pr 15 for 100 dollars shipped? should i
tommymagal
it is possible to buy a setup or individual items 2nd hand from ebay.com
if you search you can often find some great deals for very cheap prices
