HELP! 4 Kicker 10s CVR What Kinda Amp do i use?
Username: Dtribe
Post Number: 7
I have 4 kicker Cvr 10s with no clue on what kinda amp/amps to use My budget is around 700 dual 4-ohm voice coils, power handling 50-300 watts RMS peak power 600 watts
Username: Dtribe
Post Number: 8
I hear the MTX 801D pushes them pretty good
Username: Chinorican150
New york, New york Us
Simple wire them to 2 alphasonik pma300hc amps and u won't be disappointed ... It gives 450rms per channel which is perfect for the crvs..
Username: Dtribe
Post Number: 15
That puts 450 out to 1ohm and 4ohm dvc cant be wired down to 1 only 2ohm
Post Number: 9
It will run at 2ohms I myself had 2 4ohm l5 kickers and ran them with da same 2ch amp.
