Six twelves
Username: Criminole
Tallahassee, Fl
Post Number: 7
I just came up with a lot of $, and I was wondering if you could wire six twelves on two amps, both mono. I got a really good deal on 6 2004 model l7's (100 a piece), 2 ohm, and the amp/ amps are one or two mmats 1400.1. if at all possible, could I get 2 or 3 subs that could get just as loud, that have a little more sq for about 6-700$. Thanks for the help.
Username: Mikechec9
Chicago/atlanta
Post Number: 190
two amps arent going to give you satisfaction from 6L7's. and as you seem to already know, you will have little to NO sq w/those subs anyway.
with your two amps i would push two soundsplinter rlp 12's at 1ohm. 1amp/sub.
email mike http://www.soundsplinter.com/contact_us.html regarding the enclosure size.
there are plenty of sub options, but imo, you just can't beat this sql at 215.00/sub.
http://realmofexcursion.com/videos/SoundSplinter/rli12.2.wmv
just my 2cents
Username: Big_ed
Post Number: 21
how do those soundsplinters sound? spl and sq?
Username: Criminole
Tallahassee/atlanta
Post Number: 8
one amp on each soundsplinter wouldn't overpower it? or do I need one amp for both subs?
Username: 54danny54
Post Number: 472
sly hippo get a couple 15 inch eclipse ti's lol
Username: Mikechec9
Chicago/atlanta
Post Number: 191
one amp powering both subs would be about 1400 wattsx1. that's about 700watts/sub at 1ohm.
if you dedicate one amp to each sub (i was assuming you already had these two amps) it will give you about 1000watts/sub at 2ohms.
either would be fine. it is always better to have more power than not enough.
either way, be sure to set your gains appropriately. if you don't already have both amps, you could stick with one and HIT HARD! and it would still be very clean and accurate bass.
i have posted these before, but these are other alternatives. but price/(SQL)performance, SS is my first pick.
ID Max http://www.imagedynamicsusa.com/products_page.php?id=idmax&type=sub
Digital Designs
http://www.ddaudio.com/dd/default.asp
Sound Spinter
Incriminator Audio
http://www.incriminatoraudio.com/
RE XXX
http://www.reaudio.com/html/
Ascedant Audio
http://www.ascendantaudio.com/
Adire Brahmas
http://adireaudio.com/
Atomics
http://www.atomicspeakers.com/productinformation/loudspeaker/apocalypse/ap15d2.h tml
Elemental Designs
http://www.edesignaudio.com/us.php
Treo
http://www.treoonline.com/index.html
Crystal Comps
http://www.lightav.com/car/crystal/crystal.html
Diamond Audio D9
http://www.diamondaudio.com/products/index.cfm?page=productList&type=28&line=1
JL Audio
http://www.jlaudio.com/
Eclipse Ti
http://www.eclipse-web.com/
Beyond Audio
Dayton Titanic MarkIV
