Isaac, do you know anything about ppi amps? I have an A1200 2 channel. I need to know if i can bridge it and if you would know left + and right - or vise versa? Thanks
Hey Steve, is your PPI the white art series or the black one? Here's the pin layout of PPI art series amp: Left +, Left -, Remote, Right +, and Right -. For bridging, use Left + and Right -. The total resistance has to be 4ohms.
you can bridge that amp but only at 4 or 8ohms. It is stable at 2ohms stereo and 4 ohms mono. as far as the bridging goes I am almost posative it is right pos and left neg I am gonn ahave to go check on my a600 to see but if its not I will post back. I am almost pos thats what t is.
It's the white series Isaac. Jon helped me out, thanks Isaac. I'm having a problem blowing the inline fuse when i turn up the volume. It's an 80 amp, do you think i need a bigger amp fuse? I'm running the 1200 and a 450.
