Which Amp is better for What system?
heeeeeeeeeelpppppp meeeeeeeeee
Ok, i'm going with one of these two set ups what's better..?
I could get two 12" Rockford fosgate P312D4 which go at 500W rms with two MTX MXA6001 amps, 600W rms each.
or i could get Two Alpine 12" Type R's with the alpne amp that gives 1000W RMS (1% THD)
The alpine subs also each go at 500W RMS
but.. will that amp the mrd-m1005 power the two type R's??.. i might be able to match the MTX amps with the two type R's.
what's the best set up??! thanks!!!
Username: Thrushdtd
New York
Post Number: 110
the alpine amp is not 1 ohm stable so you would have to get the dual 2 ohm version of the subs. I have not heard good things about alpine amps but have heard great things about mtx. good luck.
Username: Adamalpinedup
i have this alpine amp.....
http://www.yourcarparts.co.uk/trolleyed/images/products/mrdm1000.jpg
running a pair of 12" Alpine R-type subs (2ohm versions) see my prob thread lol
cheers adam
