2 Subs 1 Amp
Username: Kmksp4
Hi all,
I have A kicker L7 15" Dual 4 Ohm sub. The sub is wired right now at 2 Ohms.
I have it running right now on a Hifonics BX1500D Mono Amplifier 1 ohm: 1x1500rms.
I want to get another sub exactly the same as the one i have now.
On the amp i have an extra pair of speaker wire connectors. Can I put in one more of the exact sub and be ok?
Thanks
Mark
Username: Taylor17
Kopperl, Texas
Post Number: 2182
Yup... wire them in paralel... then you'll get 1 ohm, and each sub will be getting 750 watts. Just make sure the other sub is 4 ohm dvc.
Username: Kmksp4
So i can run independent wiring to each sub from the amp? I do not need to splice any wires together from either sub? I dont have to run any wires from one sub to another? I just need seperate wiring going from both of the speaker inputs to each sub?
