Best amp for 2 kicker compvr 15" ???
Username: Jerv04
hello... i want to know what kinds of amp i need... for subs i have 2 compvr 15" and have pair of 6.5 and 6x9 pioneers speakers...
I bought the Pioneer DEH-P6700MP Head unit... I want a good combination, maybe both amps same brand...
I was going to buy Power Acoustik A3000DB but some people says that are not good... any suggestions?
Username: Livinloud7
Well supposedly the PA A3000DB(Mono) puts out 1100x1 @4Ohms RMS. 1800X1 @2Ohms. That is more than plenty for 2 CVR's. Not sure about the quality though.I think the 15" CVR's put out 500 W RMS, am i correct ?
Username: Cenus
Hicksville, Ohio Usa
Post Number: 219
what is the voice coil configeration, like dual 2ohm/dual 4ohm? but if the ohms match get a mtx 801d a lot cheaper and will push those subs nice http://www.woofersetc.com/product.asp?0=362&1=363&3=2168
Username: Jerv04
thanks... i dont know abouth ohmns .... what is better 2 o 4 ohmns ???
Username: Cenus
Post Number: 224
it depends on what amp you get
