What head unit should i get?? (how cliche)
Username: Prankstar008
San Diego, CA USA
Post Number: 27
My Head unit got jacked along w/ my iPod....so..I need a new HU...I was looking at the following..whats your opinion
_________________________________________
Sony....this is the one I had that got jacked, I liked all of its feadures..especialy DSO
http://www.crutchfield.com/cgi-bin/ProdView.asp?g=300&I=158CDXF571
__________________________________________
Clarion...well respected brand...comes with features that I like...I prefer the layout of this over the Sony
http://www.crutchfield.com/cgi-bin/ProdView.asp?g=300&I=020DXZ555
___________________________________________
Blapunkt...Simple layout...attractive faceplace..not to familiar with the brand, but my friend has a sticker of theirs on his car.
http://www.crutchfield.com/cgi-bin/ProdView.asp?g=300&I=023CASMP54
______________________________________________
BASICLY...I know a bit about these units allready, I just want other opinions. My budget is $200 and I am opened to other models that I havn't listed. I am also opened to other websites, but crutchfield includes a kit and harness (both of which were jacked from me) for free. What do you think?
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 16
If I where you out of those following choices I would pick the Clarion although in that price range you should try the Alpine CDE-9845, i have the 43 and its a great head unit
San Diego, CA USA
Post Number: 31
That alpline would be perfect, but I need an aux input.
San Diego, CA USA
Post Number: 32
Is there a way to edit posts?...anyways...it has an aux input, but the built-in amp is only 16W RMS and I just sold my external amp with no plans to replace it.
Username: Illuminator
Post Number: 558
You can go to Edit Profile near the top left, put in your username and password, then scroll down and edit the posts you've made within the past few hours.
Username: H_vltg3
Unless you spend a lot like 4-500 buck you wont see that RMS go up a whole lot. You mite as well buy another external amp. Shouldn't have sold it.
