Parallel Wiring
Username: Tim_9872
Post Number: 19
Which way should I wire these subs and amp?
This way:
Or like this:
Is there a difference between the two? Every diagram I've seen describes it like the first picture which would call for the wire to be split.
Username: Its_bacon12
Post Number: 199
its exactly the same either way really, the second one is how i have mine wired
Username: Shouder
Wisconsin
Post Number: 36
Both Diagrams are wired in parallel you just have two different ways to diagram it. Don't worry there the same.
If its realy that hard then just go with the second one ;)
Username: The_master
Bellmawr, Nj Usa
both pics are sam e-parallel thus giving you a 4ohm load--
