Boston 12" G5...WTF?!?!?
Username: Transamkid2000
Post Number: 22
Ok so im looking for 2 new 12 inch subs to put into my box with 1.1 cubic feet per chamber and 600 watts rms to each sub...and i come across these
http://www.crutchfield.com/S-HmS81mVCKF7/cgi-bin/ProdView.asp?g=67700&I=065G5124
Boston G5's!? sensitivity is at 90.6 but many other sites list it as 94...I want a big spl so i keep looking and then i find these add ons...
http://www.crutchfield.com/S-HmS81mVCKF7/cgi-bin/ProdView.asp?g=67700&I=065GTR12
....WTF?!?!?
is that really true...is it a good idea to get the type of SPL im looking for?
Maybe anyone can give me their 2 cents or even recommend other SPL subs that fit what im looking for
thanks...
Username: Alpineuser
Winchester, TN
Post Number: 465
u have to be carefull when u look at the sensitivity some companies use 2.83v and others use 1w/1m. the 2.83v will give u a higher sensitivity but is kinda like cheating.
Post Number: 23
so are theses subs any good? and the 2.83 gives the sub 94 sensitivity
Username: Dropthedeuce06
Post Number: 52
g'5s will scream, heard 2 12's in a sealed box and it sounded amazing. loud and clean
