What's better, 2 10"s or 1 15" ???
Username: Jaackdeth
Burnett, WI United States
Post Number: 45
Question for the experts. What would be a better choice to put in a truck of a car, 2 10" L7 kickers, or 1 15" L7 solo baric kicker??
Thanks in advance, and what type of box would work the best of either option?
Username: Alpineuser
Winchester, TN
Post Number: 457
1 15 will be louder and go lower but the 10s will probably have a little more punch to them
Username: Jaackdeth
Post Number: 46
The 10's just don't seem to have the power to go through the car, I have them hooked up to a hifonics 1500 wired at 1 ohm. It moves my mirror, but that's about it. I don't feel them in the seat at all!! I have a vented box now, any suggestions? Thanks
Winchester, TN
Post Number: 460
then something is wrong 2 l7 10s should get fairly loud off that amp. are you sure you have them wired to 1 ohm? i would check and make sure.
Username: Jaackdeth
Post Number: 47
Yep! Ohm tested them and it's a 1ohm where it should be! Now I have the subs pointed toward the rear lights, would it be better to face them toward the back seat, and how close would I go?
I can tip them up, as the box is to long that way!!
