Problem with my sub
Username: Mickeyg
alrite ther i have a problem with my twin subs in my boot. i turned up my music and one of the subs made a cliking noise and now only plays almost silently and it was only one of the subs the other is fine? it is not fuzzing or crackling which would indicate its blown and the connections are all still ok cos its still playing but really really quietly.what do you think is wrong,bust my amp?what can i do? help please
Username: Taylor17
Kopperl, Texas
Post Number: 1998
It still moves normally?
Username: Mickeyg
no it moves only a little cos the music is so quiet so it moves inline with the quiet music?
Username: Taylor17
Kopperl, Texas
Post Number: 2015
Hmmm, what amp do you have?
It's either the amp, or the voice coil I'm guessing.
Username: Hdubb
Farmington, Nm Usa
Post Number: 1673
sounds like a loose or bad connection. did you even check it before posting?
