Audiobahn ALUM10Q Help Please
Username: Clayman612
Can all you guru's help a newbie I have just bought a new Audiobahn ALUM10Q and I have it powered by an old RF Punch Transana 60x2 I have it bridged mono but it is not enough HELP ME PLEASE What should the minimum rms rated amp be that I use on this sub
Username: Tbone
OK United States
Post Number: 103
Check the specifications on the box that the sub came in for the power rating of the amp. It should say something like 35-550 watts. thats a made up range, but it will look something like that. I would think that the RF bridged should hit that sub pretty hard? What kind of box do you have it in.
Well there is a problem with checking the box I bought the speaker used on e-bay.As far as the box I ordered a new single bandpass box but have not recieved it yet so I have it in a double bandpass box just using one side.Do you think that could be the problem
mxdude
yes, too much air space
