Need help picking a sub for my AMP please.
Username: Fknwitdee
North Arlington, NJ USA
I have a Rockford Fosgate 1000 watt 1 channel power bd amp. This model is from about 4 years ago. I had a Kicker Solo Baric on it for 3 years till it blew out. Should i get a Kicker again? i was looking at the Kicker Solo Baric L7's. Thanks for any help.
Username: Cenus
Hicksville, Ohio Usa
Post Number: 180
what are the specs for that amp
Username: Fknwitdee
Oooh man, im pretty sure the specs are the same as the current Generation of the same model of the 1000watt 1 channel amp. It was a long time ago i bought it. Heres a link for the current Generation model.
http://www.rockfordfosgate.com/products/ez2rockford/ModelInfo/ModelInfo.asp?Item Key=10063516&CategoryDesc=Power%20Amplifiers
Username: Hdubb
Farmington, Nm Usa
Post Number: 1708
i want that amp. i like them. umm how much you lookin to spend?
Username: Fknwitdee
Doesnt matter price. Just trying to match up which Kicker Sub to this Amp.
Username: Cenus
Post Number: 181
go with this sub http://www.woofersetc.com/product.asp?0=700&1=704&3=3415 it will probaly get louder than that kicker. this eclipse would work to if the ohms match up http://www.woofersetc.com/product.asp?0=279&1=285&3=1613 talk to subfanatic hes the expert with eclipse
Username: Fknwitdee
Ah i cant go with a round sub now cause i already have a box for a square sub so ill need another kicker. Just lookin to do the swap. So basically my question is if the L7 12 inch is fine or not. RMS for that one is 750 1500 is the peak. Should i just run my amp at 750watts?
Username: Cenus
Post Number: 183
well if have to go kicker then go with the l7, if your box is ported i would get the dual 4 ohm and wire it to 2 ohms, but if your box is sealed get the dual 2ohm and wire it to a 1ohm.
