Car 6 disk CD player jammed!
Username: Mfulton22
Hi everyone,
I have a six disk cd changer in my 97 Explorer. I accidently put two disks in one slot and the whole thing became jammed. Before I take it in to get fixed, is there anything I can do myself to get it out without breaking it? Any help would be greatly appreciated!
Please email me if you have any suggestions!
Thanks!
marisa
Username: Carguy
Post Number: 3232
Before you get anything fixed, get an estimate. Sometimes they will charge you more than the actual cost of a new unit!
You really need to pull out the 6cd changer and open the case. Then you should be able to pull/slide the cd out.
Most of the labour will involve removing the unit from the car.
Username: Mfulton22
Isaac,
Thanks for the advice. What is the best way to remove the jammed changer? I want to try to do it myself without breaking it.
