(1) Eclipse 15" Ti Pro |vs| (1) DD 9915
unregistered
With 1x3000rms @2ohm. What setup is going to be best for the different catergory's (SQ/SPL)? Is that too much power for either sub?
And With 1x2000rms @2ohm/4ohm. The 9500 series vs comparable 12" or 15" subs on the market (xxx,aa, etc..) i dont know whats comparable.. but i got alot of watts to throw around and i want to get the most out of my sub in spl and sq.
(i wont run anything more than (2) 12"s or 1 15")
Username: Dankman
South Bend, Indiana United States
Post Number: 172
I think if you got the Eclipse TI Pro you would get some Monsterous bass with the power you got, the DD 9915 would be loud also but i would go with the eclipse TI pro in my choice, i believe it handles more power anyways.
Username: Alpineuser
Winchester, TN
Post Number: 431
the ti pro is a sql sub and the dd is a spl sub. the dd will be able to edge it out in most cases i would say
Username: Subfanatic
Walton, Ky
Post Number: 4124
the ti pro is NOT a sql sub alpine
Username: Jonathan_f
GA USA
Post Number: 4051
SQ of the Pro sucks compared to the Ti, too much motor, overemphasizes bass, and isn't ideal in factors such as moving mass, inductance, total impedance load, and so forth. It's along the same lines as the DD subs are, extremely strong motored subs built for SPL. DDs work better for SPL though, due to their suspension design and overall motor strength.
Username: 54danny54
Post Number: 339
well no1 else answer
thankx 2 jon lol cause when hje explains it....nuttin else matters
Username: Bassfreak596
Post Number: 98
DD all the way !
i own an eclipse Ti,heard the pro,n the DD too.
go for the DD you shall not be dissappointed.
Walton, Ky
Post Number: 4127
what size ti?
unregistered
SO the Ti Pro and the DD 9900 are both SPL subs? out of those your reconmending the DD? Is 3000rms to much?
If i went with the 9500 series how much power could i safely get away with using? Any other sub better than the 9500 series in SQL?
unregistered
bump
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 560
the 9500 series is not an SQL sub.. it is an SPL sub... they have recently made the 9500e whiich has a little SQ but still not a SQL sub
unregistered
oh from the description i thought thats what they were getting at..
how much power can the 9900 and the 9500 safely handle.. Is 3000rms to much for either?
Username: Basshd
Post Number: 60
3000 rms is to much for a daily driver on either sub, but for comps/burps 3000 is fine for the dd, not sure on the ti, as i am not familiar with that sub.
Username: Zacdavis
Beloit, Wi
Post Number: 76
Dankman, so you think 2 Ti's will handle all eight of these amps?
Btw, thats 20,000rms watts.
Post Number: 571
trevor doesnt think so lol
Walton, Ky
Post Number: 4165
yea it can be done as long as you dont exceed its thermal limits
Username: Zacdavis
Beloit, Wi
Post Number: 78
Post Number: 578
you are one crazy bastardd lol
Username: Zacdavis
Beloit, Wi
Post Number: 79
All on 2 9915's
Post Number: 584
just burps right?
this is your car? or one u saw at a comp?
Username: Zacdavis~
Post Number: 514
one of my older competition cars. Pics were taken in my shop. Did 158 legal sealed on the dash T/L. not bad but not great, the box was not efficient at all!
Besides, i built that for a one time "anything goes" local spl competition. got ripped apart the next day lol. (but it did win the 2sub class)
Post Number: 586
damn.... that crazy.... and a ton of money lol
Username: Hdubb
Farmington, Nm Usa
Post Number: 1674
thats all you got? weak. jk. whatas up with the 2 different log in names zac?
