Kappa perfect 6.1
Username: Shanmag
Post Number: 15
thinking about getting a pair, they are 4ohm so does that mean i have to get a more powerful amp to run 100W to them?
im looking at the DCX 500.2 and it says it runs 125Wx2 for 4ohm?
Username: Shanmag
Post Number: 16
or would the JL slash 300.2 be a better amp? 150Wx2 at 4ohm
im pretty sure these speakers r 4ohm?
Username: Jbailey
Indianapolis, Indiana
Post Number: 112
Hey shanmag, you are correct the Perfects are 4 ohm speakers. Any of the amps would be fine, but more power is usually never a bad thing. Actually, one of the Infinity reps told me that they prefer to run at least 150 watts RMS to really make the Perfects shine and handle the increased impedance at the crossover point. However, I have a friend who runs an Alpine amp rated at 75 X 2 RMS into 4 ohms and his Perfects sound great. I don't think you could go wrong with either of those amps power-wise, however, the JL is definitely a better quality amp and might offer noticeably better sound quality. I actually have a set of the Perfect 6.1's that I intend to sell in about a week or so if you are interested. I have had them for a couple months and they have been pampered. They are as close to new as a used set can get and I would let them go for $150 plus actual shipping costs to the buyers location. I have accounts with ebay and Paypal as well to assure a legitimate and efficient transaction. If you are interested let me know, and if not then good luck with your system. The Perfects are very nice and will not disappoint if you decide on them. Thanks.
Username: Shanmag
Post Number: 17
hey thanx for ur offer but im not buying anything yet, wont need them for a while anyway! sorry
some people say they have 2 pairs of these, whats the advantage of having another yet? i heard that 1 pair will be sufficient
Kyle Allen
Hey Justin Bailey. I will take those infinity kappa's. I live an hour west of Indy. Call me. 1-217-304-5780. or email ktallen21@hotmail.com
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 605
Stay away from the PPI DCX series amps. PC/PCX and Art Series are good amps, but the DCX is less than notable on reliability.
THe only reason to run more than one set of speakers is so that passengers in the back can have rear fill. Other than that it is useless. It distracts from the music in front of you, and it cost more money to buy anopther set and then power them. There really is no point in having rear speakers.
Username: Shanmag
Post Number: 22
thanx for ur help! although i have another question!
is it worth while getting a pair of 5.25 mid bass speakers aswell as the 6.5 perfects just for added kick or whatever?
