Amp for 2 6x9s
Username: Tim_9872
Post Number: 31
Do you think its worth the money to buy an amp for two 6x9s or is running them off the HU going to yield the same results (just quieter). To make this happen I would have to buy another amp, distribution block, increase the current amp power wire guage and maybe add crossover. So is it worth $200 for this upgrade? Could you suggest a good, moderate priced 2 channel amp with 60-75w rms per channel with rca outs. Thanks.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1525
JBL P180.2
if you want to upgrade, that's a good amp to use on the cheap.
a P80.4 bridged would work, too.
